CMP Test
Old Feb 4, 2006 | 09:11 PM
hotrodrx7's Avatar
Default CMP Test
Is there a way to test the camshaft position sensor? (2001 ls1) I have a constant 5v across the sensor signal (brown/white) wire regardless of the cam rotation. Thanks in advance for the help.
Old Feb 4, 2006 | 11:20 PM
kp's Avatar
kp
I believe if you have a voltmeter between the signal and ground wire it should fall to zero when the cam sensor 'hits.' Since the cam sensor is 180* cam rotation on or off and rotates 1/2 crank speed you will have to turn the engine over at least once by hand to see a change.
