car troubles after cam swap
Old Feb 4, 2006 | 09:46 PM
Tmoney's Avatar
Exclamation car troubles after cam swap
I did a cam, push rods swap and now i got smoke from my number eight cylinder from burning oil. It was the only plug i pulled out that was soked in oil. But I only did a cam swap with the heads on the car so the clyinder was never exsposed. Well the car starts and runs a lil rough like its missing had the ls1 edit put on it so i know the mis is not from that. it wasnt that big of a cam so i kept the stock spring in it so could that be a problem. I've run about 800 mi on it so any idea its the normal finger print smoke can be disragared. But like i said the only clinder geting oil is the number 8 so help or insight could be helpful.
Old Feb 4, 2006 | 09:48 PM
redtail2426's Avatar
what are the cam specs??
Old Feb 4, 2006 | 09:51 PM
Tmoney's Avatar
Z+220 SDPC LS1 Custom Camshaft - 220/224, 0.551/0.551, 114
Old Feb 4, 2006 | 09:52 PM
618HAWK's Avatar
Might have a bad valve seal for that cylinder,
Old Feb 4, 2006 | 09:54 PM
Tmoney's Avatar
but it was like it went bad over night what would have caused that
Old Feb 4, 2006 | 09:55 PM
stock springs are a no no with a cam like that,you might have broke one.dont run it at all until you check it out real good.
Old Feb 4, 2006 | 10:07 PM
618HAWK's Avatar
Busted spring and then a damaged valve stem seal, good chance that is where your oil is coming from.
Old Feb 4, 2006 | 10:28 PM
cowboysfan's Avatar
you better pull valve cover before next start. dont want more damage if you allready did.
fuerzaws6
Old Feb 5, 2006 | 12:20 PM
SSDoubleK's Avatar
Wink
Cam like that you needed to upgrade the valve springs,you have a seal that also needs replacing.
Old Feb 6, 2006 | 05:38 PM
Tmoney's Avatar
are ls6 springs tough enough
Old Feb 6, 2006 | 06:09 PM
bigman's Avatar
just go with a 918 spring. And it sounds like you need a new seal.
Old Nov 23, 2008 | 08:04 PM
camaroIroc's Avatar
ls6 "yellow" springs would work. rated at .570 max lift.
Old Nov 24, 2008 | 07:01 AM
vettenuts's Avatar
You need to change the srpings but I would check your spark plug wire. Is it oil or black soot? If black soot, it is not firing correctly and likely just the wire not connected properly. I recently did the same thing so start with the simple things.
Old Nov 24, 2008 | 09:46 AM
01ssreda4's Avatar
look into PAC beehive springs. they are a little cheaper then comps and just as good. and surely you aren't gonna say that no one told you that you needed to replace valve springs???
