Lunati vs Eagle rotating assembly
Or is a 370 a less expensive way to go; it is if you use a stock crank but not if you use a lunati. And if you would just use a stock crank in a 370 then why go with a lunati for the 408? $2000 is a good reason for a serious debate I think. Car might never see 600hp but longevity is a big factor here. Tighter tolerances and balance usualy means longer life or am I wrong?
