What rod and piston with 3.900" stroke?
Old Feb 6, 2006 | 09:07 PM
Hemi Killer's Avatar
14 Second Truck Club
Default What rod and piston with 3.900" stroke?
(LS1 block)Is it 6.200" or 6.125"? I want to use a Mahle Piston set-up, flat-top and whatever other specs to get a 10:7-11:1 comp ratio with 5.3 heads milled .010". Thanks
Old Feb 7, 2006 | 12:03 AM
Beast96Z's Avatar
You can use either, but you need to make sure that the piston manufacturer knows how long the rod is so they will know where to place the pin. I would use the 6.125 since they are the most common and have the most brands to choose from.
