Yella Terra shim question...
Old Feb 6, 2006 | 10:58 PM
Wino's Avatar
Default Yella Terra shim question...
I purchased a set of yella terra 1.7 rockers from a fellow ls1tech member who didn't have the shims that some with these. Would ANYONE happen to know the thickness of these shims? I've searched high and low and can't find anything. Any help would be much appreciated.
Old Feb 7, 2006 | 05:32 AM
Wino's Avatar
TTT
Anyone?
Old Feb 7, 2006 | 07:05 PM
Wino's Avatar
One more try....
Old Feb 7, 2006 | 09:41 PM
Ryan02SS's Avatar
I've got them in the parts bin and I will be able to get you the numbers you need by tomorrow morning.
Old Feb 8, 2006 | 05:56 AM
Teutonic Speedracer's Avatar
I'm curious as well. I'm going to be using .062" shims on my Harland Sharp rockers and am wondering if that will present valve cover clearance issues or not?
Old Feb 8, 2006 | 12:18 PM
Ryan02SS's Avatar
I've had trouble locating them and my last spot would be in my attic. I'll keep looking but I would also try contacting Yella Terra for the shim size.
Old Feb 10, 2006 | 05:18 PM
Wino's Avatar
Thanks man. Anyone else?
Old Feb 10, 2006 | 10:47 PM
Ryan02SS's Avatar
Found em! .49 thousandths off my dial calipers. Sorry for the wait. Hope this helps ya out.
Old Feb 11, 2006 | 12:02 AM
Predator's Avatar
.049, or 49 thousandths.
Old Feb 11, 2006 | 08:29 PM
Wino's Avatar
Thanks a bunch guys!
Old Feb 12, 2006 | 12:21 PM
Ryan02SS's Avatar
.049 Was a little tired typing that one.
Old Aug 24, 2008 | 11:49 AM
dz999's Avatar
You can get different size shims from McMaster Carr. On my Yella Terra's I ended up with 0.090 shims to get a centered narrow wipe pattern. You really need to check the wipe pattern to determine what size shim to use. Almost every uses at least the shims they provide about 0.050.
Old Aug 24, 2008 | 01:26 PM
triggerjerk's Avatar
PM Vettenuts.
He is pretty well versed on setting up valvetrain . . .
Old Aug 24, 2008 | 01:28 PM
frito1's Avatar
Haha... I'm hoping after 2.5 years that the fella got his yella's set up
