HELP! Where the heck is my oil going...?
The engine only has 39k miles on it!! I've had it since 33k miles and I've put all of my 6k miles on it in a little over only 2 months.
It's not leaking. There are not wet spots anywhere on the engine. I had the transmission off about 3k miles ago and the clutch was clean - the rear main isn't leaking. There are no puddles underneath it (except the occasional drop from the seeping pinion seal on the 10-bolt).
It has to be burning it. But then, why no blue smoke? And how could this happen to an engine so young?
I'd pull the plugs and have a look-see but I'm scared of what I might find and don't want to spend all weekend cussing and cutting my fingers while pulling the rear plugs.
Is my engine going bad already? I don't care if it goes bad, that would give me and excuse to swap it for a stroker motor, just not now! I'm trying to buy a house!
