pushrod length?
Old Feb 8, 2006 | 10:53 PM
scarbrow's Avatar
Default pushrod length?
i am installing a lunati T1 cam 221/221 .558/.558 in my car, i was wanting to know if i would need to use 7.375 pushrods, or if i would need to use 7.400 pushrods. stock heads and rockers. any info is appreciated.
Old Feb 8, 2006 | 10:57 PM
cowboysfan's Avatar
if you are using same heads, not milled. probably not.
fuerzaws6
Old Feb 9, 2006 | 05:51 AM
PREDATOR-Z's Avatar
7.40's will work.
Measure your cam base circle.
(Stock Base C) - (T1 Base C) = 1.55 - (T1 Base C) = (0.XX)
(0.XX) / 2 = (length of increase in p-rod needed) = (0.YY)
If that figure (0.YY) is more than .025 but <.050, then you'll need 7.425
If less than .025, then 7.40
