Please Help!!
If it's straight you need to pull the head.
If there is no compression problem at all, then you might need to reconsider the source of your loud ticking, and swap the coil for that cylinder with another cylinder.
Just because the power feels the same, doesn't mean anything. You can easily lose 10% of the power and not really be able to tell.
I'm not saying you should ignore the possible implications of the sound, just don't use the ticking sound as your only consideration in making a diagnosis.
