Lock washers OK on cam bolts?
Old Nov 1, 2007 | 02:47 PM
SSANIMAL's Avatar
I Am Having This Same Problem On A New Ls6 Motor I Got Bolts Came Loose After 2 Months Driving The Car Then I Fixed It And Now After Two Weeks Bolts Came Loose Again What Is Causing The Bolts To Get Loose. And I Also Did Not Remove The Rockers So Cam Did Not Move At All Cam Was Not Seated All The Way In Was A Little Passed The Retainer Plate Would The Caused It To Have This Problem Do I Need To Loosen The Rockers To Put The Cam In All The Way In Then Thighten The Cam Bolts Any Help Would Be Helpfull Thanks
Old Nov 1, 2007 | 03:44 PM
kerryt1's Avatar
No, no, no. Threadlocker is fine. Sounds like it's time to invest in a torque wrench.
