custom length pushrod??
Old Feb 13, 2006 | 11:21 AM
c5dream's Avatar
Default custom length pushrod??
What sponsor on this forum can get me a set of custom length pushrods? I need 7.035 length 5/16 .080 thick wall. Also how much?
Thanks,
Old Feb 13, 2006 | 11:25 AM
vettenuts's Avatar
How important is the 7.035 vs. 7.050? Many can get the latter length as Crane, Manley and Comp all will make them.
Old Feb 13, 2006 | 12:16 PM
c5dream's Avatar
I have 7.050 but needed to shim up the shaft roller rockers to get correct geometry. Thinking I could get better over valve geometry with the 7.035 pushrod.
Old Feb 13, 2006 | 12:54 PM
2xLS1's Avatar
Thanks,
Are you sure you're not wanting 7.435? Is this for an LSx application?
Old Feb 13, 2006 | 01:02 PM
c5dream's Avatar
Positive, i have the patriot shaft mounted roller rockers. Also have morel lifters which sit a little higher, and a thinner head gasket.
Old Feb 13, 2006 | 04:17 PM
vettenuts's Avatar
I am running Crane rockers, and will be installing the Morel lifters. I am expecting my pushrods to shorten about 0.090 when I put in the Morels.
PM sent.
