What piston dish?
Old Feb 13, 2006 | 07:47 PM
mypoorLS1's Avatar
Default What piston dish?
My heads have 62cc chambers. I didn't think I wanted any dish. But the smallest dish Mahle has is -4cc. Will this be too much? I kinda wanna keep compression up. BTW its a 346 not a stoker or anything.
Old Feb 13, 2006 | 08:31 PM
moeZ28's Avatar
with the mahle's its not an actual dish, but two valve reliefs. i got mine today. if you need more compression after you use these pistons, just check your piston to valve clearance and mill the heads accordingly. thats what i am gonna do with the Forged 348ci i am building.
Old Feb 15, 2006 | 04:15 AM
camaroguy26's Avatar
just use a compression ratio calculator online, and if it's not enough compression get a smaller gasket, or like moe said mill the heads. or try to get a shorter deck clearance or taller compression height
Old Feb 15, 2006 | 06:32 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are you wanting to go wiht a solid roller setup or some monster cam?
