Doing Heads and Cam pkg, few questions.
Im doing a head and cam package on a "budget."
Dont have endless pockets!
Wish I did.
Mod list:
-PRC LS6 heads with STOCK size valves.
-Dual springs
-TSP MS3 Cam Package.
Now I was told I should do these things too, but do I HAVE to do them with the package or can they wait...
-ASP underdrive pulley.
-FAST 36lb injectors (stock zo6 injectors arent enough for 460rwhp?).
-Ported LS6 oil pump, double roller TC, and 160 thermos.
Already Done..
-TPIS Longtubes
-Halltech Stinger.
-GHL Catback
-TNT Wet kit. (might not spray this season)
Thanks guys!!
-Zee
Mod list:
-Dual springs
-SVO 30lb injectors (they're cheaper and rated at 36lbs on our cars)
-Ported LS6 oil pump (Really not necessary, the ZO6 one you have is fine)
-Double roller TC
-160 thermos.
I'd at least do the LS2 chain as it's only like $35, and if you're oil press. is good and you have minimal miles you "should" be able to get away with the stock LS6 oil pump.
I'm running cam only around 440whp on stock 28lb injectors, but that's not to say that I wouldn't mind a set of 30lbers......
Good luck and remember you can recoup some money from your stock heads to pay for those extra parts that you may want to do....
Alan
