which 224
Old Feb 18, 2006 | 12:48 AM
SLP4CamaroSS's Avatar
Default which 224
i got a 2000 m6 which 224 cam should i get from what i seen some peopel with a m6 go witht the 224 with a lsa of 112 and the auto with a 114
Old Feb 18, 2006 | 01:08 AM
or would the cheatr cam be a better way to go. plan on getting heads, headers, and ls6 intake. heads are a maybe
Old Feb 18, 2006 | 01:14 AM
Warbird98's Avatar
The 114 will have a broader powerband with smoother idle. The 112 will have a narrower powerband with a bit of choppy idle
Old Feb 18, 2006 | 01:42 AM
Avengeance's Avatar
Id go with a 114.. I had one and see my sig for the results with other bolt ons.
Old Feb 18, 2006 | 01:59 AM
Warbird98's Avatar
Go with the 224 cam if you are doing LT headers and intake.The cheatr cam is far stock manifolds.
Old Feb 18, 2006 | 10:19 AM
4mula's Avatar
224/224 581/581 114 lsa
Old Feb 18, 2006 | 11:53 AM
davered00ss's Avatar
Moderator
The 112 LSA will make more power down low. The 114 LSA will idel better. That is why they run a 114 LSA on Automatic cars.
Old Feb 18, 2006 | 11:54 AM
Moderator
Call Thunder Racing and ask about their cams. They will be able to give you better information.
Old Feb 18, 2006 | 03:11 PM
nice number avge that would **** me off being that close to 400 u are holding back .3hp sounds like an answer cam i see your time is it possible to get in the high 11s with that cam w/o heads or pposibbile hit 400 w/o heads
Old Feb 18, 2006 | 07:25 PM
Ragtop 99's Avatar
the 112 cam is better performance, 114 is a little easier to tune with cats.
Old Feb 18, 2006 | 08:03 PM
INMY01TA's Avatar
Get the 112lsa.
Old Feb 18, 2006 | 09:37 PM
should i get teh tr224 cuz i know there alot of 224 made by differnt companies
Old Feb 18, 2006 | 09:42 PM
INMY01TA's Avatar
Thunders 224/112 kit with 918 springs,hardened pushrods is what I got. I'd go with the titanium retainers as well.
Old Feb 19, 2006 | 08:37 AM
Moderator
The TR224 is a well proven cam.
Old Feb 19, 2006 | 10:10 AM
4mula's Avatar
comp cams makes most of the cams for alot of tuners.
im a fan of the 224 581 114 lsa cam.
