piston to vaulve clearance issues?
Old Feb 19, 2006 | 10:32 PM
dirty2kTA's Avatar
Default piston to vaulve clearance issues?
on stack motor how many of you guys have ran into piston to vaulve clearance probs. what cam? and in particular MTI's Y1 (234/240 .598/.608 113).
Old Feb 20, 2006 | 08:08 AM
GuitsBoy's Avatar
Most cams up to and including the T-rex (which has larger specs) will clear the stock heads, unless of course stated otherwise. Its usually once you install larger valves or start milling the heads that you run into p to v clearance.
