Have A Quick ? About Oil Temp.
Old Feb 22, 2006 | 09:24 AM
BIG_MIKE2005's Avatar
Default Have A Quick ? About Oil Temp.
I'm ordering a oil temp. gauge & need to know what temp range is needed for our cars. One gause goes up to 300* & the other is higher. I just wasn't sure what temp our oil runs.
Old Feb 22, 2006 | 09:27 AM
Cstraub's Avatar
180 degrees is minimum before you flog on an engine, 210 to 220 is optimum temp. 230 to 240 is the max oil temp you want to run. Over 240 the engine will still operate but this will cause bearing fatigue and shorten the engines life.
Old Feb 22, 2006 | 09:29 AM
Thankx for the info.
Old Mar 18, 2006 | 08:58 PM
1QWIKBIRD's Avatar
Question Oil temp - Best place for sender?
Where would the best place to pick up the temp of the oil? I have an oil cooler on the car, so I have a few unused ports on the adapter? Or should I have a bung welded into the oil pan?
Thanks
Chris
Old Mar 20, 2006 | 08:36 AM
Cstraub's Avatar
The Pan is the best place.
