H/C install question
Old Feb 24, 2006 | 11:56 AM
mmorrison09's Avatar
Default H/C install question
ok im having this installed next week, is this everything i would need?
ms3 cam 237-242 603-609 113lsa
comp prc springs
tsp pushrods
Ti Valve Spring Retainer with std locks
comp 850-16 lifters
yella terra roller rockers 1.7:1
double roller timing chain
fms ported oil pump
ls6 heads from a 03 zo6
arp head studs
all new bolts and gaskets etc.
speed density tune by SQR
That should be every thing i need right.
Old Feb 24, 2006 | 12:06 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Looks good to me. What length are the PR's?
Old Feb 24, 2006 | 12:09 PM
evergreen0077's Avatar
might want to look into injectors, i just did heads/cam and im guessing most likely ill need new injectors, ill know for sure when i get it dyno tuned though in spring
Old Feb 24, 2006 | 12:12 PM
Joel_SS's Avatar
Why are you going with new rockers? Aren't the stock 1.7? They should be fine..
Old Feb 24, 2006 | 12:16 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Injectors would be a nice addition. Maybe some 30# SVO's or a little bit bigger.
Old Feb 24, 2006 | 12:26 PM
99blancoSS's Avatar
with that cam he's playing in the 6500-7000 rpm range. An upgrade at the rockers isnt that bad an idea, but certainly arguable as to needed or not. Some say 6500 rpms is the limit they would run stock rockers at
Old Feb 24, 2006 | 02:05 PM
they are 7.40
Old Feb 24, 2006 | 02:07 PM
just to be safe, plus i got them for a hell of a deal!
Old Feb 24, 2006 | 02:10 PM
yeah ive been thinking about injectors also, cause im gonna spray too some time in the future.
Old Feb 25, 2006 | 05:44 PM
i talked to the guys at the shop and they said that my injectors would be fine until i spray it but to go ahead and upgrade to a racetronix fuel pump.
Old Feb 25, 2006 | 07:52 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Spray Ehh??? I think that if you do anything over a 100 you will want to go 42# just so you don't lean out and ....*poof* LS1 Soup.
Old Feb 25, 2006 | 08:30 PM
eamador11's Avatar
make sure you do a stg 2 port job on those z06 heads otherwise why bother putting that big of a cam in there.
