trex dyno graph
Old Mar 1, 2006 | 11:34 PM
2002blkss's Avatar
Default trex dyno graph
ideas and suggestions!
Old Mar 2, 2006 | 12:45 AM
SlickVert's Avatar
Looks good.
You need to flatten out your AFR line, it went rich right after 6,400 rpm.
I do like how it started kicking after 4,500.
At 6500 it looks like it is making more then 60hp more then you had, and at 7,000 more then 90 hp.
What was your WOT timing set at in the higher RPM?
Did you try adding timing to see what it liked?
I think it should be 29 to 30
