fix my own engine ?
Old Mar 4, 2006 | 12:03 AM
anthonyz281999's Avatar
Default fix my own engine ?
well i recently put a rod through my motor with N20....and now i am buyin a short block from another member here...im not expercence with motors but i have a general idea....ive done lawn mower engines etc...jw how hard its gonna be takin my old motor out...and transfering heads and cam etc from my old motor to the new motor...should i be able to do this ?? i just dont wanna get it back together and have it break cause i messsed something up...any input will be great guys ..thanx
Old Mar 4, 2006 | 01:04 AM
2K2WS6TA's Avatar
Should, it's not that hard, keep the connectors labeled, the bolts can go in bags with a label to tell what they are, get a service manual,, so you have all the torque specs, a digital camera to take pics of brackets, hose routing, etc.
Just be organised, methodical, and patient, and you should have a running engine in no time
Old Mar 4, 2006 | 06:26 AM
ace68's Avatar
Your best bet is to get a book like (how to build chevy ls1/ls6) and there is another I have but don't know the title. They have important info in there like specs and tips I wouldn't attempt it without using one of them. For instance if you don't clean out the taped holes in the block for the heads you can crack the block when you run the motor.
Old Mar 4, 2006 | 09:30 AM
ashade98's Avatar
Go for it! If you have patients and can turn a wrench (in the right direction) you can do it. Take 2K2WS6TA's recomendations!
Old Mar 4, 2006 | 09:39 AM
mtb989s's Avatar
I was in the same boat as you. I just did the head and cam swap on my 2000 ws6. It took a lot of patience, I didn't label anything and still managed to get it back together perfect. But unless you have a good memory or get really lucky just bag and label everything and take some pictures. If you have any question pm me and I'll see if I can help.
Good Luck!
Old Mar 4, 2006 | 09:49 AM
IrateTA's Avatar
The H/C swap won't be so bad, but swapping engines will be tough. I suggest you read-up on the steps involved because its not your typical cherry picker swap.
