How to make oil pick up align/fit?
How are you guys making it fit?
How much are you shimming the windage tray? When I did my 402 the pickup tube lined up fine. Can you post a pic if possible?
BTW - If you need some help let me know.
Gino
Gino
Note: My oil pump is already torqued down. Should I remove the bolts bolts until everything else is installed?
Thanks
I guess I will have to wait until I can get a pic later this week.
Then I f'd up the rear main cover trying to remove the old seal
. Guess I am ordering a new one! Then I f'd up the rear main cover trying to remove the old seal
