New Cam Specs
Old Mar 5, 2006 | 11:24 AM
noah89's Avatar
Default New Cam Specs
I'm looking for more bottom end torque along with peak HP. I'm told with a dyno tune I should be able to build lower end torque and at least another 35 rwhp. Also, even though I no longer have to pass the sniffer, just the OBDII scan, do you think this cam could be EPA compliant? The cam is supposed to be very tunable and quite stealthy. My car is a street car and goes to the track once a year for a few timeslips. What do you think? Thanks.
Comp Cams
Comp Custom Grind Cams
Cam Duration Lift LSA
int. exh. int. exh.
228 222 .588 .581 114.5
Old Mar 5, 2006 | 11:30 AM
s346k's Avatar
i don't think that would be a very good cam, as those reverse split cams like very free flowing exhaust, and i think your cats will choke off any potential of low end tq. you might consider a 220/224 or the standby 224/224. maybe even a 224/228 if you are feeling frisky.
Old Mar 5, 2006 | 11:33 AM
PREDATOR-Z's Avatar
Will pass with proper tune. -4 degrees overlap
Old Mar 5, 2006 | 03:32 PM
Patrick G's Avatar
LS1 Tech Administrator
For more bottom end torque, you want to close your intake valve earlier. This will give you increase cylinder pressure and more low end torque ( at the sacrifice of top-end power). A 224/224 110LSA, 110ICL cam would be a better approach.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 5, 2006 | 09:17 PM
Ragtop 99's Avatar
Cut it back to a 226/222 113 109 and you'll get better torque. A 224/224 113 110 would probably work better.
Patrick, your suggested cam will make great torque but take a serious tune to pass a sniffer if he ever wants to do that.
Old Mar 5, 2006 | 11:35 PM
PREDATOR-Z's Avatar
That is the 224 I suggested they run on A4's instead of 114+4 (LSA), and at -2 degrees overlap it would pass sniffer with proper tune. i like your way of thinking Ragtop 99
