408 "Q"
Old Mar 5, 2006 | 05:56 PM
scalemaster's Avatar
Default 408 "Q"
well just want to know is there anybody runing the MTI stg2 R heads with this size motor
Old Mar 5, 2006 | 11:49 PM
PREDATOR-Z's Avatar
You can but it is recomended to run stage III big bore chambers instead. Unless you are at very high compression (like 12.5:1 +), you would be leaving lots of power on the table.
And if you did so, you better pay attention to your cam grind for DCR values.
Old Mar 7, 2006 | 05:05 PM
thank's
so stg 3 here we go
Old Mar 7, 2006 | 05:33 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Sal,
Those heads could be opened up to get the job done. It'll cost a bit, but they will work. Like Predator stated the upgrade will be well worth the $$. You could always sell them and buy a set more appropriate for your big bore plans.
Those are really good heads for the 3.90 bore/smaller cube guys. There is a market for them.
Good luck to ya buddy!!!
Old Mar 7, 2006 | 06:18 PM
thank's James
well I'm getting ready for the big buy
