Help me pick a cam
Old Mar 6, 2006 | 07:20 PM
JacobK's Avatar
Default Help me pick a cam
Alright guys its time for me to buy a cam. What would be something good for what i want, i want it to be driveable since i do drive this car everyday, however i dont drive it really far. but i want something that makes good power throughout the RPM range, im kinda afraid of having to spin the cam up really high since i have 118,500 miles on the motor, and i need it to last this season. Also i want something thats gonna sound rowdy as hell at idle. So if anyone has any recomendations i would really appreciate it, also if you can give me specs on the cam that would be awesome guys.
Thanks
JacobK
Old Mar 6, 2006 | 07:41 PM
98camaroLS1M6's Avatar
224/224 would be a good size, not too big, but not too small, good amount of lope, but not overkill.
Old Mar 6, 2006 | 08:06 PM
radz's Avatar
the cheatR cam from thunder racing might be a good choice also, not a big cam but you will notice the difference, and its the same powerband as stock, that what I plan on using for my daily driver
Old Mar 6, 2006 | 08:10 PM
00cls1camaross's Avatar
on camaroz28.com you said you wanted to run n2o so get a nitrous grind cam...
Old Mar 6, 2006 | 09:00 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Maybe a 230/232 or something to that effect.
Old Mar 6, 2006 | 09:24 PM
BigDaddyBry's Avatar
If you want nitrous along with your other requirements, I would suggest either the GM hotcam or a 224/228 .581/.588 112lsa.
The reason I throw in the hotcam is because it fits your "rowdy" requirement, is a split duration for nitrous, and would not be too hard on your valvetrain (given your mileage).
Old Mar 7, 2006 | 01:13 AM
JacobK's Avatar
no im not going to use nitorus..Also im not too worried about driving it, cause i am going to be getting a daily driver soon so thats not a problem..i just want a cam that i wont really have any problems driving, is what i meant to say. Im thinking the HPE "S" cam on a 113lsa. or possibly the TSP 231/237 wahtcha think
Old Mar 7, 2006 | 01:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
A split would only really matter in the event that you were going to spray the thing to make retarded amounts of power.
Old Mar 7, 2006 | 05:31 AM
s346k's Avatar
the cam spins at half the speed of the crank.
224/228 - splits also help broaden the powerband. maybe on a cam that small with only 4* separation it wouldn't be too noticeable, but nonetheless.
i'm trying to work up a larger duration cam with 8* separation for a n/a motor, i think it will work well. scavenging is increased with a wide split..
Old Mar 7, 2006 | 06:01 AM
1fastz28nx's Avatar
MS3.........it's awesome
Old Mar 7, 2006 | 05:43 PM
JacobK's Avatar
ttt...
Old Mar 7, 2006 | 06:12 PM
gettinthere's Avatar
Jake, I ordered my new one. If you want my current one, let me know.
Old Mar 7, 2006 | 07:51 PM
SUTTERERMAN85's Avatar
i got a 228/232 on a 112 lsa way streetable and broad power also
Old Mar 8, 2006 | 02:14 PM
JacobK's Avatar
ttt...
Old Mar 8, 2006 | 02:40 PM
prostock_bigblock's Avatar
Try to stay on the 228 -234 duration range . here r some good choices:-
* 228/232 on a 112 lsa
*F13 , F11
*G5X2
*thunderracing 230/236 .
*thunderracing 231/234 .
*MTI R1 , 232/236
*TSP Torquer 2 .
Old Mar 8, 2006 | 07:28 PM
You really can't go wrong dude. If you follow prostock_bigblock's advice, the spread on those cams is probably no more than 20rwhp.
Just pull the trigger.
