head bolts or studs??
Old Mar 6, 2006 | 08:57 PM
1998TA__1991RS's Avatar
Default head bolts or studs??
im going to be running a forged 346 with a trex, heads, and a 200 shot of gas, which would suit my application better?
Old Mar 7, 2006 | 09:15 AM
NHRATA01's Avatar
I'd definitely say just spring for the studs. They're really better all around. And well worth it if you plan on pulling the heads more than once - easier clean up, and less wear and tear on the block threads. I went with the bolts for a mild H/C setup, and kind of regret not going with the studs. The bolts are fine for what I need them for, but I know if I ever have to pull the heads again its going to annoy the hell out of me, and then I'll probably spring for the studs.
But with a forged setup, big H/C and 200 shot I'd think even from a reliability standpoint the studs would be superior for that kind of stress. They should provide much better clamping.
