Stock/Factory Machining
Old Mar 9, 2006 | 10:12 PM
Adnectere's Avatar
Default Stock/Factory Machining
Ground up buildup
On a fresh from the factory block, do you need to do block machining?
On a fresh from the factory set of heads (or after) do you need to do the machining?
