serious knock retard!!!
Old Mar 18, 2006 | 10:55 AM
curtisad's Avatar
Default serious knock retard!!!
I have a 98 Z28 and when I am at WOT in 3rd I start getting some massive knock retard around 3500 RPM's! I have been told by a buddy that the 98's were programmed super sensitive? I am wondering if I have a problem or should I get the sensors reprogrammed?
Old Mar 18, 2006 | 11:12 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are you throwing a code that can be picked up with AutoTap or something?
Old Mar 18, 2006 | 11:14 AM
peterock98's Avatar
I also have a 98.Make sure your exhaust is not banging and your spare tire and jack are fastened. Also with ls1 edit you can take out knock sensors.
Old Mar 18, 2006 | 11:18 AM
curtisad's Avatar
not throwing any codes
Old Mar 18, 2006 | 11:25 AM
Torqued's Avatar
How much KR are you getting? I have basically given up on trying to remove the 4 degrees I get at WOT. I have gone throught the hassle of replacing the knock sensors, runnning 100 octane gas, getting wide-band measurements, etc etc in hopes of identifying a cause.
Where did you buy the Voodoo cam?
Old Mar 18, 2006 | 12:00 PM
curtisad's Avatar
I don't know how much timing I am losing. I can feel it and hear it though! Sounds like I am slamming into the rev limiter just at 3500 RPM's! I am assuming that is the knock retard? The rev limiter is set to around 6K. I witnessed that feeling when I was about a quart low on tranny fluid and started slipping like a maddog and the rpm's shot through the roof for a split sec!!
Old Mar 18, 2006 | 01:02 PM
RedHardSupra's Avatar
98's are notorious for overzealous knock sensors, there should be an update for them, you basically get the 99+ ones. try it, just might solve your problem
