3 compression ratio??'s
Old Mar 18, 2006 | 04:00 PM
brad8266's Avatar
Default 3 compression ratio??'s
I plan on picking up a set of 6.0L heads to lower my CR a bit for a future blower plan, what will the CR be with just the head swap and is there any machining that can be done to the head to increase the CC's in the chamber?
Also is it a good idea to use dished pistons as well to get lower? I ask because the dish will take area out of the piston top and couldn't it make it weaker? I just dont want a weak piston because I am probably gonna spray as well and dont wanna crack a piston because it is dished.
