MS3 Cam/ Gears? So my car is at the speed shop right now getting the MS3 Cam (Custom grind but very similar) and 3500 Stall installed with TransGo kit and a Dyno Tune with H.P. Tuners. Problem is the car currently has 273 gears in it, I would like 410's but they would break in a 10 bolt (I've done it before on stock cam&stall on street tires) so I was thinking of using a factory setup of 342 gears cause I can get the whole rear end for $50 if In trade mine. Will that gear combo be OK with this cam or no, I do not have the $$$ for a bigger rear end right yet. :confused: |
I'd say slap in the 3.42s that will help and when you decide to go to 3.73s you can use the same carrier. :) Hawk :devil: |
410's break?wat exactly u mean by that? |
Pretty much a waste of money to go from 342 to 373 but You got a good point about the carrier. |
Originally Posted by HottLS1Z Pretty much a waste of money to go from 342 to 373 but You got a good point about the carrier. then 4.11s And if you can only afford the 3.42 rearend it kind of takes the guess work out. Hawk :devil: |
By "breaking" I mean multiple pieces of pinion gear teeth and ring gear teeth busted off and then destroying the carrier |
The speed shop is saying I will need 410 gears with a cam this big or it will drive like sh*t... |
i have 3.73 and a 3500 stall and im fine |
if you dont mind the higher hwy rpms id 4.10 though i think next time round ill go 4.10 |
ah mabye 4.10 and a tci 4400 stall would be good! |
are u buying the magic stick v.3 from tsp or from somewhere else that sales the same spec off a cam?tsp told me that on a auto to get the most out of the cam 410's is it but now for a daily driver 373's will help keep the conveter tight.so go with 373's but just remember that cam will runner better with lower gears |
I have 3.73's in mine and I am pleased, but after super chevy I am gonna put in a 4.56 for the local 1/8 mile track and try to go 6.99 N/A... good cam choice by the way, and PTC can build you a hell of a 4400 converter... |
If your spraying can I stick with the 3.42 gears and the ms3. Or are 3.42s just not enough for the ms3? |
I would go 4.10s and just be cognicent(spelling?) that it could break. Ive been driving around with my 10bolt with full boltons and drag radials and Mine has no signs of breaking yet...knock on wood. Just be somewhat careful. You with definately enjoy the 4.10s with that cam. |
Originally Posted by CraZee ZO6 If your spraying can I stick with the 3.42 gears and the ms3. Or are 3.42s just not enough for the ms3? |
Anybody??? |
So to anybody running this cam in a a4 car what gears have you tried? Also has any one ever had any engine problem with this cam? and what are you shifting at? |
6600 rpm shifts is what tsp reccomended its a great cam anf i run 3.73 gears with a 3500 stall although eventually ill probally get a 4k stall im very pleased with the results |
Originally Posted by HottLS1Z The speed shop is saying I will need 410 gears with a cam this big or it will drive like sh*t... |
Yeah I have the girdle had it when i broke y last set of 373 and 410 gears, what is this about welding the axel tubes though??? |
© 2024 MH Sub I, LLC dba Internet Brands
