Anyone ever blown a headgasket before?
Old Mar 22, 2006 | 02:56 PM
maxf's Avatar
Default Anyone ever blown a headgasket before?
If so, what were your symptoms? Aka how did you know it was blown? How much work was it to replace? Did you do it yourself, or pay someone to do it?
I think I may have blown my headgasket... (oil on spark plugs, white smoke out the exhaust usually during idle, SES light for random/multiple misfires)
Old Mar 22, 2006 | 04:56 PM
orion565's Avatar
check your oil to see if its milky murky, as if water got into it
Old Mar 22, 2006 | 05:08 PM
Keenov's Avatar
For a blown head gasket, check for loss of coolant.
Sounds like you might have a more internal problem.
Old Mar 22, 2006 | 05:32 PM
Layn_Low_247's Avatar
I have one, same symtops. Plus I'm having to refill my collant every 3-5 weeks.
Old Mar 22, 2006 | 06:47 PM
JZ'sTA's Avatar
To replace the gasket its the same job as doing a head swap.
PITA but you could do it if you had some time some tools and do it while your relaxed, b/c I promise if you do it already mad this will just make it worse.
gaskets are cheep, but to pay a shop to do it will be between 550-1000 dollars for both heads.
Old Mar 23, 2006 | 11:45 AM
Nate_Taufer's Avatar
You'll most likely see a milky white sludge inside your oil fill cap. Do you still have the stock PCV system? Try deleting it and see if the issue gets resolved.
Nate
