Cam geniuse for and A4 LS1 Help!!
Old Mar 23, 2006 | 09:39 PM
01ls1lover's Avatar
Default Cam geniuse for and A4 LS1 Help!!
OK! i want to put a 224 224 114 ls1 cam in from futural ... I know i need springs and rods rite? but do i need a converter as well??? somone help me with my delima...
Old Mar 23, 2006 | 09:44 PM
4mula's Avatar
yes, youll need one.
something along the lines of 3000-3500
Old Mar 23, 2006 | 09:53 PM
01ls1lover's Avatar
So what should i buy.. i know everyhting has to match what would i need to buy to have that cam in a daily driver with no problems and cheap
Old Mar 23, 2006 | 09:58 PM
waterbug1999's Avatar
Yea the stalls mentioned above will be good for a daily driver. Fuddle is having a sale till the end of march on TC for 350 bucks. Not bad if you ask me..
Old Mar 24, 2006 | 05:05 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you plan on doing a stall and a cam at the same time that is a good idea. If you have to do one, then the other. Get the converter first. cammed a4 with stock converter will leave a ton of power on the table. Tht is my best "genious" guess for you. Other than that you really can't go wrong with that cam either way. definietly get a converter though is all i am saying.
Old Mar 24, 2006 | 08:39 AM
4mula's Avatar
get a stall between 3000-3500. that rpm range goes right into the powerband of a 224
Old Mar 24, 2006 | 09:43 AM
01ls1lover's Avatar
but will it hurt anything if i dont get a stall rite away....? Also would i need to do anything to the rearend? i dont think i should...?
