head and cam prob.
I installed a set of 98 style stage 2 ported heads that have 2.02 and 1.6 valves with comp 918 springs and tit. retainers. The heads were also milled 30 thousands. The cam I went with was a 226/226 with 581 lift. I kept the stock length pushrods with this set-up.
I have been around carb engines for some time and just expected the throttle response of my ls1 to be close to the carb set-ups.
I wasn't for sure if this was just a tunning problem or if it was something else.
Thanks for the help,
Adam
I just read a post about a guy that had to long of push rods also. At the time of the install I had done some searching on here and guys had been running the same lenght pushrods, but now I guess people are seeing that the different length pushrods should be used.
I am planning on getting a tune here in the next week or two. So I guess I will see what happens after that.
Thanks for the help so far guys.
