hot cam
Old Mar 28, 2006 | 06:44 PM
Blackss99's Avatar
Indyboom,
I have the hotcam and love it everyone is biased with their cam.
So I suggest you do some research and decide. here are something's to consider. How much power do you want? Maintenance is always a factor for example some of the bigger cam's require you to change the valve springs every 20,000 miles. And alot of them don't bring the power until you are high in the rpm's. Last but not least the hotcam is pretty inrxpensive. Good Luck!
Old Mar 28, 2006 | 07:52 PM
indyboom's Avatar
Oh im final on it.. Its mild yet radical.. I would always take a OEM engineered performance part over non OEM.. Its funny how everyone likes to push there cam on you!! Everyone has good info though! Thanks
In D
Old Mar 28, 2006 | 08:42 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
^ OEM engineered means nothing. It's pretty much a carry over grind from the LT1 days.
I wouldn't limit myself to a Hotcam without researching what a cam like a Thunder Racing 224 or the aforementioned Futral F10 can do for ya. Futral F11 is a sweet cam worth looking into.
Old Mar 28, 2006 | 08:57 PM
Hennytime's Avatar
from what ive gathered about the hotcam (i had one in my hands for a couple of week and sold it for juice) i liek it because its cheap (i got mine and springs all for 200) the power peaks only 200-300rpm higher than stock, which will keep wear and tear on other vital parts low, and not worrying about the springs keeps you well in mind. if i had more money and another car *** a daily, hell ya id do a huge cam and heads but for the time being this car is my dd and it needs minimal down time
Old Mar 29, 2006 | 08:26 AM
BerryWS6's Avatar
if your set on GM stuff get the ASA cam it has the .525/.525 lift but a bit more duration I think at 226/236 and its on a 110LSA so you know it will sound good with a overlap of 11*@.050 and I beleive it will make more power and torque
Old Mar 29, 2006 | 08:41 AM
!LS1 11 Second Club
+1 for the ASA.
Old Mar 29, 2006 | 09:03 AM
jmm98LS1's Avatar
+2 for ASA, biased of course.
Old Mar 29, 2006 | 11:02 AM
bomb3r13's Avatar
+3 The ASA cam is a torque beast!!
Old Mar 29, 2006 | 11:35 AM
indyboom's Avatar
Originally Posted by indyboom
HaS anyone ever use a GM hot cam kit? Im looking at putting one in my ls1. Do I need to reprogram my comp? Or should I just use a ls6 cam?? Im looking for power and still having good MPG
You have DIGRESSED from this original question. At no time did I ask about another cam??!!!
Old Mar 29, 2006 | 11:41 AM
indyboom's Avatar
Ok.. I had two guys that were going to sell there Hot cam too me. They both had approx. 7500 on it and included the springs, I was to send them a money order. Some how all my messages got deleted? If this person is you please resend me your info... I am going to save it.. and send the check out!! Thanks
Where you at guys??
