Quick question about patriot heads.
Old Mar 27, 2006 | 08:15 PM
5.3litre's Avatar
Default Quick question about patriot heads.
I bought some patriot stage 2 ls6 heads a while back intending to use them on a N/A motor but my plans have changed as usual and i ordered a turbo kit. The heads have a 59cc and if im going to use them i need around a 72cc. Is it possible to go from a 59cc to a 72cc if i take them to a machine shop?
Old Mar 27, 2006 | 09:37 PM
JoeyGC5's Avatar
Gunnar should be able to do something for you
Old Mar 27, 2006 | 09:52 PM
Xtnct00WS6's Avatar
My 243 casting Patriot heads are around 62cc and was thinking in a few years that I could just have them machine the combustion chamber to open them up a bit. I guess it's all dependent upon ur goals. I guess it's not the *best* solution, but would work just fine depending on the amout of boost. Part of the gm casting might be a little too thin in some areas to want to have a lot of boost with.
Old Mar 27, 2006 | 10:47 PM
~JOSHUA's Avatar
Patriot should be able to work things out with you. They know their reputation lives on this board and I'd bet they'll do what ever it takes to make you happy. -Joshua
Old Mar 27, 2006 | 10:51 PM
gomer's Avatar
I promise you if you call Gunnar.. he will do whatever it takes to make you happy. Customer service one thing Patriot can't be called out on.
Old Mar 28, 2006 | 09:22 AM
Gunnar@Patriot's Avatar
Posted on your other thread, just give us a call and we will go over the options.
