lunati 395 stroker
I had to clearance the block so the rod bolts wouldn't hit, but thats about it. Everything has been right on. It was balanced by them and everything has been right on, every step of the way.
Here's a post I had a while back about the stroker kits, https://ls1tech.com/forums/showthrea...ht=stroker+kit, I came to the conclusion that it is cheaper to build a 402 or 408 than a stroker 346 and you have a brand new block and all. It's up to you but the 402's and 408's look like a better choice.
What heads and cam did he go with?
It has a Fast 90mm intake and had a TPIS 90mm TB that was hell to tune, now it has a LS2 TB and it looks like it is going to work better. I still have some left to tune.
IMO, I think the car would make a little more power with stepped headers and the FAST intake port matched, a little more compression wouldn't hurt either. It screams as is though.
https://ls1tech.com/forums/generation-iii-external-engine/441706-edelbrock-victor-series-headers-not-56k-friendly.html
