Custom cam ordering
Old Mar 28, 2006 | 08:02 PM
UltraZLS1's Avatar
Default Custom cam ordering
I am placing an order with speed inc for a custom cam.
they have no form to fill out or anything and they just said to put the specs in the comment box?
I dont see how that is a very good way of doing things.
Anyway...what all do I need to include? every little detail? or will they just do what they want with the stuff I leave out? I am confused,
I dont even see anywhere on the site where I can purchase a custom cam?????
What all do I include? duration at 50?duration@.006? lift at 50 ? gross lift? lsa and icl? what else? should I specify xer lobes or just set the duration at 50 and duration at .006 to 49 apart?
I basically want an f11 size cam on xer lobes
I need some help. Anyone else order a custom cam from speed inc?
thanks, Troy
Old Mar 28, 2006 | 08:08 PM
Ksett's Avatar
If I were you I would be asking these questions in detail to Speed Inc tomorrow before you do any ordering.
Old Mar 28, 2006 | 08:09 PM
UltraZLS1's Avatar
I have e-mailed them a couple times and they said it would be best to just put the specs in the comment box because they are very busy.
hmmmmm
Old Mar 28, 2006 | 08:16 PM
CRL 01 SS's Avatar
I would talk to them over the phone. Ask them to make a form where you can fill in the info that they'll need. Then they'll fax it over to you. You fill out the information, and then fax it back. Ask them to send you a fax confirmation. That way you'll have exactly what you ordered in writing and there will be no questions about who was wrong just incase something were to go wrong.
Old Mar 28, 2006 | 08:39 PM
Beast96Z's Avatar
Enter Comp grind 3724/3725 HR112+4 if you want to be as close to the F11 as possible. You cna swap the LSA and advance if you like, but that's up to you. Other than that, they don't need any more info. It would be really hard to screw that up.
Old Mar 28, 2006 | 08:54 PM
algws6's Avatar
you might want to check this out.
http://www.compcams.com/Technical/Cu...ML/238-273.asp
Old Mar 28, 2006 | 09:27 PM
UltraZLS1's Avatar
Hey beast...that looks like it would do from the link algws6 gave me...thanks by the way.
And these are xer lobes as well.
looks like I have found my cam
thanks guys
Old Mar 30, 2006 | 02:51 PM
UltraZLS1's Avatar
Well...I placed my order today.
The guy didnt even seem to know what I was talking about when I said lobe number etc....but I told him intake lobe 3724, exhaust lobe 3725, that I wanted a lobe separation of 112, and that I wanted 4 degrees of advance.
I dont know...he just seemed kind of...new or something...nice guy though.
Think I should be ok?
and the good thing is....he said it would only be about 3 business days.
Old Mar 30, 2006 | 04:58 PM
Beast96Z's Avatar
Make sure you check the cam card and the butt of the cam for the grind number when you get it. 3 days seems awful fast. Comp usaully has a 2 week turn around. I'd expect 3 days if they had it on a shelf, but I doubt that.
Old Mar 30, 2006 | 07:40 PM
UltraZLS1's Avatar
The butt of the cam should say 3724/3725?
And I planned on checking the cam card as well.
3 days did seem kind of quick...I can wait two weeks I guess.
thanks again
