Which Heads I need it with G5X3 and ....
Old Apr 3, 2006 | 02:00 PM
SideStep's Avatar
Originally Posted by JRracing
How much flycutting do you think might be needed for this to work?
Just did a set of AFR205s (59cc) and a G5X3 (114lsa) for a buddy. LG told us to cut .080 on the intake side only and we did... I think you can run the same cam with 66cc AFRs and not flycut. Also, we used Cometic .045 head gaskets...
Old Apr 3, 2006 | 02:36 PM
JRracing's Avatar
I'm not doing something right!
Old Apr 5, 2006 | 11:11 PM
SideStep's Avatar
How much did you end up cutting???
Old Apr 6, 2006 | 06:57 AM
ss2002's Avatar
Hi,
Thanks for all
i'm thinking of AFR 205 59cc but i don't wanna get into high comp. issues ....(50 C temp. and 92 octane) so what do y'all think???it's my DD
should i get the 62cc or 66cc???and what head gaskit to use (stock thinkness??)...i don't want to flycut anything
And what is better 3.73 or 3.91 diffratio for my A4 ?! 4l6e ?!
Thank you,
Old Apr 6, 2006 | 07:05 AM
JRracing's Avatar
To much. like .170"
The exhaust clears by a mile and the int has about .100". A lesson learned I guess. I'm very confident that it will be OK. TSP said they cut the same amount on a car and sprayed it with a 200 shot. It held up for two years before trashing a rod. So I should be ok.
Heres some pics.
Old Apr 6, 2006 | 07:09 AM
JRracing's Avatar
Originally Posted by ss2002
Hi,
Thanks for all
Thank you,
I think you might clear with a 62cc and I know it would with 66cc's. I'm using a stock gasket because it came with the gasket kit. And TEA told me to use a stock gasket.
As far as gears, I would run a 3.73 if I were you.
The cam should be ok for a DD once tuned properly.
Old Apr 7, 2006 | 04:55 PM
ss2002's Avatar
Hi all,
I have ordered AFR 205 66cc with the G5X3-114
Do you think the GM Multi-Layer Steel LS1/LS6 Cylinder Head Gasket is good ?? or THE Cometic Gaskets will be better ??! please tel me what is the thickness and bore I need it with the G5x3 and AFR 66cc to take the best way.
and is it the springs which come with heads is good or need change it with G5X3 ?!
and is it COMP 7.400" CHROME MOLY PUSHRODS is the right choose ??
Thank you,
Old Apr 7, 2006 | 07:10 PM
JRracing's Avatar
Ask LG Motorsports what gaskets and push rods to use. The will know better than anyone!
I think you will be very pleased with those heads and cam.
Old Apr 7, 2006 | 09:47 PM
93ChevExt5.7's Avatar
Hi all,
Thank you,
LG normally goes with Comp 921 springs with their G5X2-114 (what I have) and currently have the AFR205cc (milled to 59cc)
Old Apr 8, 2006 | 10:55 AM
JRracing's Avatar
I would use 921's or PP gold .650's.
Old Apr 8, 2006 | 11:08 AM
ss2002's Avatar
thanks,
but no body tel me about the Gaskets NO's "thickness and bore I need it with the G5x3 and AFR 66cc"
Thank you,
Old Apr 8, 2006 | 11:54 AM
  #32
john59's Avatar
I'm running G5X3 on 114 and I'm going with Dart 225's out of the box with a little touch up work. I was told to use stock GM gaskets from Dart part # 12498544 and I will check valve clearance to see if i can mill any,let you know what it Dyno's, Mike Norris is going to tune it next week.
John
Old Apr 10, 2006 | 10:22 PM
  #33
alsfastz28's Avatar
I thinking on going with that same set up as john59 keep us posted using 112 lobe center my car is a4 too.
Old Apr 16, 2006 | 08:02 AM
  #34
ss2002's Avatar
Hi,
Thanks for all.
I have ordered those parts :
98-02 LS1 /1996 LT4 Breather
Chrome Moly Pushrods 7.400 (Stock Length)
SLP Double Roller Timing Set
SLP Heavy Duty Oil Pump
AFR Mongoose 205cc FULLY CNC 66cc Chambers COMPLETE
ASP CRANK AND ALTERNATOR SET LS1
2004-2005 160* T-Stat
MSD LS1 8.5mm Super Conductor Plug Wires
NGK TR-55-6 Set of 8 Spark Plugs
Vigilante 9.5" 5-Disc Torque Converter 4L60E 3200
Nitto 555 245-45R17 Radials (Pair)
Stainless Works GTO Headers - Off Road
Drive Belt for use with underdrive pulley
SLP GTO Linelock
G5X3 - 114 Cam
ARP LS1 Hex Head Bolt Kit
COMETIC HEAD LS1 GASKETS 3.910 BORE .040"
ARP Header Stud Kit, LS1,LS6, 5.7L & 6.0L
ARP torque convter bolts 113-230-7305 -TR
valve spring upgrade for AFR heads
ARP LS1 BALANCER BOLT
Isky Piston Notching Tool, 2-1/8" Diameter
Isky Piston Notching Pilot, 5/16" or 8mm Valve Guide
TCI Automotive SFI Approved LS1 Flexplate, 1998-2002 LS1
F-body & 1999-up GM Trucks w/ 4.8, 5.3 or 6.0L
I want to say Thank you to:
1-Mr.Fraser from www.ls1speed.com
2-Mr.Bobby from www.lgmotorsports.com
3-Mr.David from www.thunderracing.com
and for the all who is help me in these thread
Finaly How many HP you think I will take with thes parts ??? with my A4
Old Apr 19, 2006 | 07:54 AM
  #35
roadrash9r's Avatar
Just going to have to put it on the dyno and let us know.
