Need info about TXspeed 408
As for power potential, any of the off-the-shelf pistons are rated by the manufacturers for up to 200 HP shots of nitrous. For anything past that, they recommend building a custom piston with lowered ring lands. We've built quite a few engines with custom Diamond pistons for big nitrous and big boost applications. Depending on the options selected with the pistons (i.e. dish, flat-top, or dome, standard or upgraded tool steel wrist pins, ceramic coating, HD steel top piston ring, etc.), a custom set can add a few hundred dollars pretty quick. However, if you're looking to hit the engine consistently hard with big power-adders, the few hundred spent now will save a lot more down the road.
Feel free to call, PM, or e-mail me at trevor@texas-speed.com with any other questions or concerns. I'll be glad to discuss your options with you to build the engine to suit your needs.
Trevor
Texas Speed & Performance
