bent pushrod or dropped valve????
Old Apr 3, 2006 | 12:12 PM
steveo346's Avatar
Default bent pushrod or dropped valve????
well.....yesterday night i went from 3rd to second going about 95mph at the track not on purpose but because my stoopid tranny had been acting up....now my car is spudering and the service engine soon light is blinking constantly and well the car feels like ****.....i hope its nothing major,so any feed back welcome
Old Apr 3, 2006 | 12:30 PM
brad8266's Avatar
I would take it all apart and have a look, dropping to 2nd at 95 is very bad. The blinking SES means misfiring. Take off the valve covers and check it out.
How the hell did you downshift like that anyway??
Old Apr 3, 2006 | 12:33 PM
steveo346's Avatar
i didnt downshift....i was trying my hardest to go striaght into 4th but like i said my stoopid tranny has been acting up
so........i want to cry........its my daily driver
Old Apr 3, 2006 | 01:46 PM
TheBlurLS1's Avatar
That's what she said...
It'll be fine. I've done it more than enough times. My trans is old and tired as well. You most likely bent a pushrod. Mine ran like crap, sputtered, SES light on etc. for a few miles then started running fine again once or twice when i did it.
Yank the valvecovers and rockers and check the pushrods. This happens all the time, so don't worry. Replace the bent pushrods with new STOCK ones. Hardened pushrods and stock valvesprings spells death if this ever happens again.
When you shift into 4th, turn your hand over to where your palm is facing the passenger door and your thumb is pointing at the shift boot. This will help you keep it out of 2nd gear. I started doing this and i never did it again. You have to be conscious about doing it before you run though or you will forget. Now-a-days i just pull on it at a 20* angle toward 6th though, with my hand right on top of it like normal, works fine for me!
See the vids of me at the track for a demo.
Old Apr 3, 2006 | 04:10 PM
brad8266's Avatar
Or get a pro5.0 with LSS, then you wont miss anymore.
Old Apr 3, 2006 | 04:23 PM
prostock_bigblock's Avatar
you will get this code P0300 msfire, anyways i have been in same situation before and changed heads and 2 bent pushrods.
Old Apr 3, 2006 | 06:03 PM
davered00ss's Avatar
Moderator
pull the pushrods out and find out. Have the code scanned and find out what it is. Also have the code erased. It will come back if the problem is still present. It takes about 15 min to pull the pushrods.
Old Apr 3, 2006 | 07:32 PM
eallanboggs's Avatar
When your MIL flashes it means you tailpipe emissions are bad enough that if you continue to drive without making a repair you're going to damage your cats. The EPA is more concerned with your cat than they are with the condition of you engine.
 Michael S. Palmer
Old Apr 3, 2006 | 11:17 PM
DAVESS02's Avatar
Cats? People leave those things in?
Old Apr 4, 2006 | 01:45 AM
Dmoney's Avatar
The misfire codes were coming from #5 . We checked the pushrods and one is strait as can be. The other is slightly off, but not enough to just look at it and say it's bent. Pulled the spark plug and Not bent or melted, but pitch black. the other spark plugs looked fine. What do you guys think? Bent valve or lifter gave out? We are going to put new pushrods and a new spark plug in tommorrow and see what happens.
Old Apr 4, 2006 | 02:59 AM
good luck , keep us posted.
Old Apr 4, 2006 | 08:08 AM
steveo346's Avatar
STOOPID TRANNY.....i do have a b&m ripper shifter....and i never freaking miss a gear...and i do not have cats..lmfao.....so today we are gonna pull all the rockers off and inspect all of the pushrods to be on the safe side...and then go from there...i hope it is neither a lifter or a valve but if worse comes to worse.....i will install my cam, springs, retainers and locks and new 7.4 chromemoly pushrods while im at it...oh and the ls6 intake.....but i miss my freaking car already....i left it at my grandmothers house lastnight...and it was our first night apart in a long time...im having withdrawls....lemme call my granny and she how my car is doing
Old Apr 4, 2006 | 08:26 AM
steveo346's Avatar
it was the number 6 cylinder dan not the number 5...or whatever
Old Apr 4, 2006 | 08:36 AM
indyboom's Avatar
Originally Posted by steveo346
STOOPID TRANNY.....i do have a b&m ripper shifter....and i never freaking miss a gear...and i do not have cats...but i miss my freaking car already....i left it at my grandmothers house lastnight...and it was our first night apart in a long time...im having withdrawls....lemme call my granny and she how my car is doing
Sounds to me like the problem is" A LOOSE NUT BEHIND THE STEERING WHEEL".
Old Apr 4, 2006 | 10:40 AM
steveo346's Avatar
WTF??? thats besides the point
Old Apr 4, 2006 | 12:21 PM
indyboom's Avatar
hehe....
Old Apr 4, 2006 | 05:14 PM
steveo346's Avatar
PERHAPS I SHOULD POST PICS
Old Apr 4, 2006 | 06:09 PM
indyboom's Avatar
Was it the push rods?? Are your up and running??
Old Apr 5, 2006 | 12:57 PM
steveo346's Avatar
ok today im gonna compression test the cylinder that the tech 2 told me the issue was on...when i took the pushrods out....they were all fine....so....its prolly a bent valve or lifter
Old Apr 6, 2006 | 01:02 PM
steveo346's Avatar
I TOOK MOST OD THE TOP of the engine off yesterday with the help of dmoney's company as well as mjk...i will post pics later
