AFR's or Dart's?
Old Apr 11, 2006 | 01:24 PM
kp's Avatar
kp
Originally Posted by Tony Mamo @ AFR
I hear you loud and clear....Thankfully this is America and there are many products to choose from. Some have a better fit than others and what's "right" for one guy might be "wrong" for the next. You knew you would make so much power with that combo, the money saved on heads could be used for something else. A guy trying to make big numbers N/A might not have that luxury and knowing his goals would have to purchase what he felt was the "best" for his application.
It's all good....there is plenty of market share to go around and more than enough Gen III business to keep all the quality cylinder head companies thriving.
Tony M.
The heads I ran last year (ET ported 98 castings with stock valves) worked just fine, these picked up a solid 2mph in the 1/8 with less compression so I'm happy. Only regret is these heads arent legal for the NMCA 'steet race' class and I would have liked to run a couple of those events. 221cc max runner size and you 205s are 'legal.' Hard to be cheap and try to class race lol.
Old Apr 11, 2006 | 03:29 PM
SStrokerAce's Avatar
Good luck getting a head to fit those rules and work well as a LS1 head. I've wanted Dart to make the 205cc casting of theirs legal for that class for a while now.
Bret
Old Apr 11, 2006 | 03:40 PM
kp's Avatar
kp
AFR 205s are legal, they are listed. I assume the AFR 205s are less then 221cc CNC'd. Dart 205s are listed but those are SBC heads, not LS1
Old Apr 11, 2006 | 08:39 PM
vetred's Avatar
This is one of the best "threads" Ive seen In a looooong time thanks everyone just about changed my mind on quite a few things! Thanks to everyone!
Old Apr 11, 2006 | 09:13 PM
calongo_SS's Avatar
I really don't think you can go wrong either way, AFR & Dart are both high quality heads. For my $$ though I'd go w/ the Darts.
Old Apr 11, 2006 | 09:18 PM
1QuickT-A's Avatar
Originally Posted by 4thGenCamaro
I am not trying to start a flame war here as we have seen both heads put out great numbers, both on the dyno and at the strip. I'm am all about making the most power with the least amount of money. The new program that Texas Speed has been using for their heads is awesome. You tell me which is better.
Intake PRCs AFRs
.200" 149 140
.300" 205 200
.400" 255 251
.500" 287 281
.600" 307 298
.625" 310 N/A
I just wanna know how many freakin times we are gonna have to tell people that ADVERTISED flow numbers don't mean jack ****.. ADVERTISED numbers are just that.. ADVERTISED!!! Search for independant numbers from reputable shops like W2W, Thunder Racing, HPE, LME, etc. And why does TSP/PRC NEVER post exhaust flow numbers? Hmmm...
If you want to spend a grand on a set of ported stock castings then go ahead. That might be your cup of tea. But, when I think about "going fast" or "building a nice setup" there isn't anything "STOCK" left in the equation. When you buy a set of AFRs or Darts or ETP heads you are getting a quality AFTERMARKET head that has many many many different features that make it ALOT more efficient than a ported "stock" 5.7/5.3/6.0/ls6 head.. Yeah you can work on a ls6 head for hours and hours or slap it on a cnc machine and get flow numbers that are close to the AFRs or even higher numbers in some cases. But, how efficient are the heads? What size is the intake runner on the ls6 head? I'd bet my *** that its ALOT bigger than the AFR 205 and/or the AFR 225.. What kind of velocity/volume do the ported ls6 heads have? Thats why the AFR 205s have consistantly made good power.. They are far superior to any stock head in my opinion. Some stock heads might flow more, but you have to factor in all of the other quality features that put them ahead of the stock castings.
The AFR heads are tried and true. It has been proven time and time again in dyno testing and track testing. You truly do get what you pay for. A quality AFTERMARKET head full of nice features and top of the line parts with the customer service to back it all up.. I learned the hard way when I bought my heads. I have since seen the light and realized that if you want quality then you have to be willing to pay for it..
p.s. ADVERTISED FLOW NUMBERS ARE TOTAL BULLSHIT!!
Old Apr 11, 2006 | 09:20 PM
Ksett's Avatar
Originally posted by KP
"Biggest mistake is simply assuming just because you use an AFR, ET or any other 'top shelf' cylinder head you are guaranteed big power without the proper supporting pieces, thats a bigger mistake then choosing the wrong head over others. There is a big enough market where no one should be complaining, since supply is always a probelm it appears that all aftermarket LSx heads are selling well."
"FWIW I picked the Darts because they were cheap, I am cheap - I'll admit it. But I also have had good luck with Dart products over the years and just assumed they wouldnt turn out a piece of junk. I paid for them just like anyone else (actually I paid more) and they suit my needs just fine. If I had an unlimited budget I would have a set of AFR 225s or ETs on the car, but then again if I had an unlimited budget I would have a 402 and twin T67s instead of a 346 and a D1SC also."
I think Tony is referring to the average guy that buys a HC package running an N\A setup. This is really the majority here, not many people have the luxury of running a HC with supporting mods and a D1SC.
Old Apr 11, 2006 | 10:00 PM
bichin95redta's Avatar
AFR, in my opinion, are the best aftermarket heads available. Also, in my opinion, they need to change up the way they process orders, or plan their production. Don't get me wrong, I believe the best is worth waiting for, but if AFR gets any slower at delivering, they'll start going backwards. Sometimes I think they mine their own bauxite before they cast your heads. Out of all the aftermarket parts producers I've dealt with, they are BY FAR, the slowest.
Other than that, you couldn't possibly own a better set of heads...........if you don't die of natural causes before they arrive.
Old Apr 11, 2006 | 10:43 PM
eamador11's Avatar
get AFR 205s!
Old Apr 11, 2006 | 10:47 PM
robb4964's Avatar
Originally Posted by Cbrakllr
Ok here is my plan, major power on the strip!!! I dont car if my car has no top end or anything like that. I want to run fast in the 1/4. Im looking in to heads and dont know which ones to go with, as in my sig i have the MS3 (not yet installed) so i need something that works well with that! I was looking at AFR's 225cc but they seem too pricey. but I dont know if their 205cc head would be good enough so i looked into the dart 225's and they are much much cheaper, why? Are they just as good? what head would be good for my application?
225cc is for larger displacement engines and wont be any more benefitial then 205cc heads with 346 CI.As a matter of fact you may lose some low end torque.
Old Apr 11, 2006 | 10:52 PM
robb4964's Avatar
Well put. AFR is pure technolagy. When the made the 205Mongoose heads they started form a clean sheet of paper and designed everything from scratch and basing their design off trial and error until they came up with a great set of heads.
The 205's made 530HP with a mild cam running thrue a flowmaster muffler with an otherwise stock block.
Old Apr 11, 2006 | 11:10 PM
  #32
225's are a bit much for stock CI applications.
If you go with the 205cc Mongoose heads, have 'em milled around .011", or so, and go with .040" Cometic head gaskets. I'd assume you'd also be doing a cam swap, and new pushrods? If so, a Comp cam somewhere around 222*/228*, .581/.588, 114 LSA should match up pretty well with the heads. You'll make insane mid-to-hi range power.
The LS6 intake will help, but if you can afford it down the road, get a FAST 90/90. An aftermarket oil pump (Melling, etc.) and an LS2 timing chain wouldn't hurt, either.
Of course, all of these parts will be worth about as much as a 3-foot high pile of ****, without a GOOD tune.
Old Apr 13, 2006 | 04:10 PM
  #33
You woud be amazed but there are ported LS6 heads out there that are smaller than a AFR 225cc and out flow them. That's even on a 3.90" bore. Then again they cost more than a AFR 225cc so, back to the discussion.
FWIW I'm not of the opinion that a 225cc runner is too much for a stock cube application. Even on a street car.
Bret
Old Apr 13, 2006 | 08:05 PM
  #34
Ported LSx-series heads, for being OEM components, are not at all a bad choice for a performance build. Hell, they flow great numbers right off the showroom floor...when F-Bods we're still being made.
That said, I've ridden in, raced against, and watched too many AFR-equipped cars to doubt them. AFR advertises flow numbers like everyone else does, but when I go to the track, their heads aren't on flow benches, they're on engines, and in my limited experience, I see them on more engines than any other brand, and, most importantly, they deliver the goods. I'm a member of 2 local car clubs, so I get my fair share of time at the track, cruise nights, and "on the street". Around here, AFR rules. That's not to say that they are superior to any other brand...all I'm saying, is that locally, AFR FAR outnumbers any other brand of aftermarket head.
These posts about brands (and I don't care what it is...heads, headers, cams, cat-backs,....you name it) can be interesting, and it's nice to keep up with the latest tech, but, man, I don't know of a faster way to start a war than to say, "I think brand X is better than brand Y".
And when you think about it, who is really qualified to say so? The only headers you ever see me write about, are Kooks, and that's because they're the only headers I've ever installed. I cannot honestly say they are better or worse than any other brand, because I've never had any other brand on any of my cars. How many guys have had Kooks, Pacesetter, QTP, Dynatech, Hooker, Dynomax, SLP, or Stainless Works headers on the same car, to do a valid, real-world, comparison? It's the same thing with heads. Now, you can argue price, delivery time, and customer service, but that's in an entirely different universe than performance.
BTW, AFR's own literature recommends 205cc heads over the 225cc for stock CI engines.
Old Apr 13, 2006 | 10:58 PM
  #35
Hugger's Avatar
I think the AFR's are great and I have admired them since they came out but they just aren't in the budget for most of us. I may run just a little slower than the AFR guys but I do have an extra grand in my pocket to spend on other mods.
Old Apr 14, 2006 | 10:32 AM
  #36
S10xGN's Avatar
Originally Posted by tbojbob
I'm guessing Matt is talkin' bout these from TSP:
http://www.texas-speed.com/shop/item...d=649&catid=40
Dollar wise they are a heck of a bargain, you could get a 90/90 set up with the money you saved! Personally haven't seen anything quantifying the performance of the DARTS, either size. That being said AFR's have been the pinnacle LS1 performance head that have stock valve train geometry (valve angle, rocker arm stand configuration). It's all in how much you want to spend, is 400 rwhp OK? Or, did you have 450+ as your goal.........
Why not go with the PRC LS6 heads? They are out flowing the AFRs across the board, are more than $1000 less, and keep your stock PtoV clearance.
Am I looking at this wrong? This link brings me to the PRC heads page, I add the Comp 918 spriings and CNC port, then x2 the number for a PAIR of heads (not one) and I get $2,299.98. That's certainly NOT $1,000 less than AFR's...
Russ
Old Apr 14, 2006 | 06:15 PM
  #37
kp's Avatar
kp
Russ
I'm pretty sure 'each' means pair, thats what I read a while back anyhow..
