MS3 Cam install straight up or advanced?
Old Apr 11, 2006 | 10:42 AM
SLPSS99's Avatar
Default MS3 Cam install straight up or advanced?
Like the title says should I install this cam straight up or advanced? I will be running a 200 shot on this if that matters.
If I install it advanced do I need an adj timing chain or can I use a non adj one? Which Timing chain would you use?
Dan
Old Apr 11, 2006 | 11:01 AM
Joel_SS's Avatar
You have to use an adjustable timing set, and from what I understand you do not want too much adavnce when on the hose.
Old Apr 11, 2006 | 11:42 AM
nokeman's Avatar
I put put a little advance in it to bring the powerband down a little.
Old Apr 11, 2006 | 11:44 AM
black_z's Avatar
Is there any advance ground into it Dan?
Old Apr 11, 2006 | 11:59 AM
SLPSS99's Avatar
Didn't even think of that, just talked with jon at TSP and he said straight up
Dan
Old Apr 11, 2006 | 12:06 PM
Patrick G's Avatar
LS1 Tech Administrator
If you don't advance the MS3, your dynamic compression will be horrible. Basically, it will be totally gutless NA.
When running nitrous, the motor responds to an earlier exhaust valve opening (because of the faster burn of nitrous). Here again, advancing the cam will benefit your goal of most power on the hose.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 11, 2006 | 01:16 PM
SLPSS99's Avatar
Hmm how much advanced? Like I said I talked with Jon at TSP and he said put it in straight up(dot to dot)
Dan
Old Apr 11, 2006 | 01:28 PM
Patrick G's Avatar
Dan
You may want to get a few more opinions before you do that. I would also recommend you download the DCR spreadsheet (sticky in the Advanced Tech Section). You will be surprised how low your DCR will be with 0 advance built into that cam, not to mention how late your intake valve closing point. The late IVC (with 0 advance) is not going to give you the best area under the curve with an LS6 or FAST 90/90 intake manifold (if that's what you plan on running).
Old Apr 11, 2006 | 01:37 PM
CraZee ZO6's Avatar
Why does TSP say no advance if its sucks without advance? lol
Old Apr 11, 2006 | 01:48 PM
SLPSS99's Avatar
OK I have it figured out from a guy with my same setup and he installed it dot to dot and makes great powre on and off the bottle
Dan
Old Apr 11, 2006 | 03:10 PM
SStrokerAce's Avatar
If you start advancing that cam you need to check PTV.... FWIW I don't always find more power with making the exhaust valve opening event earlier, i'd rather play with the timing of the spark instead.
Bret
Old Apr 11, 2006 | 04:34 PM
nokeman's Avatar
I feel like an ***...my response had nothing to do with your question I was confused. Sorry.
Old Apr 11, 2006 | 04:41 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Yep, if you decide to advance it, make sure you have plenty of PtoV clearance on the Intake. It barely clears stock pistons at 0 advance, which is exactly why its made like that.
