MS3 on a 112
Old Apr 11, 2006 | 03:47 PM
RoastEmSS's Avatar
Default MS3 on a 112
Does anybody have experience with the MS3 on a 112 lsa. Im deciding on getting the 113 or 112. Im wanting some more power down low and a lumpy idle so 112 would be better correct? thanks
Old Apr 11, 2006 | 04:25 PM
ThirdGenLS1's Avatar
I dont think it will fit on a 112 with out flycutting. You might want to think about going a bit smaller if you want get some more low/mid range.
Justin
Old Apr 11, 2006 | 04:31 PM
moeZ28's Avatar
why not? its smaller than a TREX that is on a 110 LSA.
Old Apr 11, 2006 | 04:32 PM
nokeman's Avatar
I agree with the above statement. I was deadset on the MS3 but I started to think about how I would be missing all the low end power. You could get a smaller cam that will make just about as much as the MS3 but with have much more "useable" power. Some of the smaller cams will also have a mean lope too so you do have to worry about that.
Old Apr 11, 2006 | 04:44 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
We've run a few on a 112lsa, but I've always check PtoV, specifically the exhaust side as the intake timing events won't change with a 112 vs a 113 on the same intake centerline. I don't think there would be much difference powerwise, or drivability though.
Old Apr 11, 2006 | 04:48 PM
n2o junkee's Avatar
I never had to fly cut mine but if you go with the 113 you'll be happy
