Pinning crank and balancer questions
My questions:
With just a H/C setup is one pin sufficient? I know some people use two, but I assume that is for SC applications. If I every do get the SC, I could add the 2nd pin at that time.
If you drill the crank and want to change the pulley at some point in the future, how do you drill the new pulley? Aligning the tool to the existing hole in the crank wouldn't be a problem, but when you go to drill, you are essentially trying to drill 1/2 of a hole because the crank is already drilled, and the new pulley is not. Do you just move the tool to a new location?
Thanks for any info on the correct way to do this.
