High milage cam swap
Old Apr 13, 2006 | 02:45 PM
BAD LUK's Avatar
Default High milage cam swap
How risky would a cam swap at 100k be?
I swapped the stocker for a hotcam/LS6 springs at ~16k. What else would I need to swap along with new cam/springs at this point?
Old Apr 13, 2006 | 02:49 PM
Vertigo's Avatar
It all depends on how you treat it. If its well maintained then you shouldn't have any issues. Additional parts also depend on what size cam your getting. If you plan on spinning it really high then i would suggest replacing the rod bolts, springs,retainers, lifters,v.seals...etc
