Iron block rod bearing clearance
Old Apr 14, 2006 | 06:37 PM
Flyer's Avatar
Default Iron block rod bearing clearance
What should it be within?
Also .. will the mains be good with .0025?
Keep in mind, this is an iron block.
Old Apr 14, 2006 | 07:23 PM
KCS's Avatar
KCS
Moderator
General rule of thumb, .001" for every 1" of bore diameter.
So for a 2.100" housing bore, .0021" should be OK.
Also, .0025" should be good for the main bearing clearance.
