More about Quench
Old Apr 14, 2006 | 06:54 PM
ssheets's Avatar
Default More about Quench
OK, looks like I've got all the tools I need to calc DCR and I'll be measuring P to v during install. Going back to the basics while reading the DCR document I was reminded of this, "Note: The quench distance (piston/head clearance) should always be set between .035" and .045" with the lower limit giving the best performance and detonation resistance."
So on a stock LS1 block and internals we can assume (will verify with micrometer) that we have an out of hole of .007" so a .040" gasket leaves us a .033" quench and a .045" gasket .038".
Is .033" too tight or is it close enough to the lower recomendation?
Conversely, is .038" in the sweet spot, or am I sacrificing a little bit of performance and resistance to detination?
Finally, how bad is .047"? (OEM gasket)
Old Apr 14, 2006 | 07:08 PM
z-ya's Avatar
I used .036 cometic gaskets for a .028 quench with good results on a stock shortblock.Aluminum blocks grow a lot more than steel so we can run the quench
tighter.
Old Apr 14, 2006 | 07:25 PM
ssheets's Avatar
What's the correct gasket bore to run on a stock bore?
Old Apr 14, 2006 | 07:29 PM
ssheets's Avatar
tighter.
What cam are you running and how does that nice tight quench do on pump fuel?
Oh and do you know your SCR and DCR?
TIA
