Oil Change After Head/Cam Install?
Old Apr 23, 2006 | 07:41 PM
JoeMack's Avatar
Default Oil Change After Head/Cam Install?
Just finished a head and cam swap. Before starting I poured oil over the timing chain and rocker arms. Buttoned it up and drained the oil. Filled with fresh oil. Started it up and ran for about 10-15 minutes. Took it down the road about 3 miles and shut it down for the night. Next day, let it get to operating temp, shut it down and changed the oil and filter (used Mobil 1 5w30). My question is, am I good to go until normal oil change interval or do I need to change the oil again sooner do to the H/C swap? Thanks
Old Apr 23, 2006 | 08:02 PM
conan's Avatar
That sound's good. How many miles do you go for your oil changes? You might want to do it alittle sooner than normal, just for a good piece of mind.
Old Apr 23, 2006 | 08:17 PM
JoeMack's Avatar
Normal change interval for me is about 5K miles.
Old Apr 23, 2006 | 09:52 PM
Steve Bryant's Avatar
LS1 Tech Veteran
I don't think that you need to change the oil sooner than normal. If this was a freshly rebuilt engine, I would recommend an additional oil change in 1,000 miles due to the minor amount of metal you would be getting in the oil as the rings seat to the cylinder walls. However, a cam with roller rockers, etc. are not producing any little metal shavings to amount to anything at all. You are good to go in my opinion.
Steve
Old Apr 24, 2006 | 07:56 AM
REDWS6ROCKET's Avatar
you should be ok, i don't ever let mine go 3,000 miles though. that is just me! also you should use a thicker oil like 0-40 or 5-40, the thicker oil will help slow down oil consumption with a cam heads as well.
Old Apr 24, 2006 | 12:24 PM
JoeMack's Avatar
Thanks everyone.
