need help with oil pump..
Old Apr 24, 2006 | 11:41 PM
staringback05's Avatar
Default need help with oil pump..
i think my oil pump might be goin bad, it idles a lil off when warmed up and the flow moves between 25-35 psi when warmed up. theres also a very very slight hollow slap, or thump sound which doesnt sound to bad. so does this look like it could be going bad? does it throw a code or what, i mean how can i tell? the oil looks good and it hasnt leaked any, doesnt smell burnt or anything. also where is the oil pump located? as in reference to?? how much do shops usually charge to change one out?....i know these might be newbie ? but i gotta learn sometime, thanks
Old Apr 25, 2006 | 12:16 AM
Texas-TA's Avatar
How many miles?? Just drop a cam in there and throw a ls6 oil pump in while your there
Old Apr 25, 2006 | 01:33 PM
75k and the cars under warranty for another 10k so otherwise i would do exactly that. but this is my daily car and its just important to know if its gonna blow up on me or something. right now it feels fine other then the slight wabble in the idle and the gauge psi.
Old Apr 25, 2006 | 05:22 PM
Red99C5's Avatar
The oil pump is right behind the crank pulley/balancer, and in front of the lower timing chain sprocket. I read that you only need about 10 psi for ever 1000 rpm. I am changing my pump with the new LS4 pump. I would recomment installing a LS2 timing chain while you was in there. And it would be a very econimcal time to change the cam too if you had plans for it.
Old Apr 26, 2006 | 01:39 AM
hmm so im guessing the engine will have to be pulled to replace this? and not to sound like a jerk but 10 psi sounds a lil low for every 1000rpms. my cars under warranty and i cant really add aftermarket internals to it, i just really needed to know what kinda deal im getting into here, if this is gonna take a week or what. is there anything else internal that could be doing these symptoms besides the oil pump?
Old Apr 26, 2006 | 04:23 AM
ashade98's Avatar
You could do it yourself. Check LS1howto.com for an idea of what's actually involved. The motor DOES NOT need to be removed! Should take a good shop a couple hrs. The dealer on the other hand.... probably a couple days
Old Apr 26, 2006 | 05:35 AM
eallanboggs's Avatar
75K miles and still under warranty? What a deal! You must have bought this car used which is another way of saying you don't know the history of this vehicle. That being said you have no way of knowing whether the pressure gradully dropped over time or suddenly plumetted the day before you bought it. This isn't the type of thing that will set a DTC and cause your SES to come on. If your oil level gets too low you will get a warning on your message display, but you not currently worried about that. LSX engines make plenty of oil pressure seeing as how the pump is crank driven rather than cam driven which reduces output because of the reduced speed. Chances are your OK, but if you're a wrench turner you can get the pressure back up for under $200.
Old Apr 26, 2006 | 12:37 PM
i did buy it used, it had about 50k on it and i got it for 12k out the door, i had someone check it out and it seemed good. ive got another 5k on the warranty so thats why if its goin out i want to get it done. ive had it for about a year, and i have noticed the psi dropping lately, i was planning on putting a ls4 pump in when i get some zo6 heads and cam, but i dont think i can wait that long now. thanks for the info im calling my warranty company today
Old Apr 26, 2006 | 11:20 PM
Texas-TA's Avatar
Actually the cam swap isnt hard at all. My brother and I finished his a fe wmonths ago. It took us about 10 hours total but we werent working too hard
Old Apr 28, 2006 | 05:19 AM
Bigdeezs's Avatar
Anyone happen to know the part number for the LS4 oil pump?
Old Apr 28, 2006 | 01:20 PM
im gonna try to get the shop to put in a new ls6 or ls4 pump instead of the ls1 ill have to see what there gonna say
Old Jul 31, 2006 | 09:57 AM
joe c's Avatar
LS4 Oil Pump - 12571885
uses LS1/6 O-Ring - 12557752
Old Jul 31, 2006 | 10:14 AM
mcowart's Avatar
if its the dealership they are gunna say no..we only put in what it comes with
Old Jul 31, 2006 | 01:32 PM
Uthinkso's Avatar
Ok help me out here, I know LS1/LS6/LS2/LS7. Even the LQ4/LQ9, but what is an LS4?
