any heads over 72cc?
Old Apr 26, 2006 | 04:11 PM
kumar75150's Avatar
Default any heads over 72cc?
Im thinking about lowering my compression to put a blower on the car but I really dont want to screw with changing the pistons for now.
Old Apr 26, 2006 | 04:19 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
How big do you want? I have a 74cc setup
__________________
Old Apr 26, 2006 | 04:37 PM
kumar75150's Avatar
im waiting on more kenne bell results
with a 74cc head and .074 cometic head gaskets, id be at 9.5-9.6:1
Old Apr 26, 2006 | 09:19 PM
02TransAm/Batmobile's Avatar
according to this chart, the 2001+ lq4 6.0 liter heads yield a compression ratio of 9.1 when swapping to a 5.7 liter engine, "this is the workhorse head for street/strip turbo and blower cars"
Old Apr 27, 2006 | 08:07 AM
CHRISPY's Avatar
Kumar,
Be careful with manipulating gasket thickness. You want to maintain good quench/squish.
Often slightly higher comp with better quench is less prone to detonation that lower comp with poor quench.
Cheers,
Chris
Old Apr 27, 2006 | 10:57 AM
kumar75150's Avatar
ya im thinking of keeping the nitrous setup and going with lower pistons if i ever wanna put a blower on the car
whats the thinnest 4.1 bore headgasket?
Old Apr 27, 2006 | 11:12 AM
JZ'sTA's Avatar
I would defentially not run that big of a gasket.
You can get down to 9.5:1 with no problem on a stock LS1 with a 74cc head.
9:1 will be tough. Anyways 9.5:1 will be fine.
Look at all the stock Z06's with 10.5:1 running FI.
Old Apr 27, 2006 | 03:27 PM
kumar75150's Avatar
i dont have a stock motor
408 with -9cc pistons
anyway, if i ever decide to do it, ill switch to -25ccish pistons
Old May 5, 2006 | 08:39 PM
alexf20c's Avatar
lmao @ 4.1 bore
Old May 5, 2006 | 11:47 PM
kumar75150's Avatar
Originally Posted by alexf20c
lmao @ 4.1 bore
Alex, I already told you.
Do you want to race?
1000 bucks
Ill give you 10 car lengths
