Detonation, STOCK CAR!???
Old Apr 26, 2006 | 07:37 PM
ritefulback's Avatar
Default Detonation, STOCK CAR!???
Ok so i bought my first ls1 WHOO HOO
but its still detonating even after i replaced the knock sensor i was told to replace (told me it wasnt retarded timing because they were faulty)
so i replaced em....still got the knock
Im guessing its running lean, so i need to know how many possibilites it has to go wrong
fuel filter im doing tomorrow
after that i have no clue
any advice to diagnose it would be great
2002 ws6 m6 32k miles with no SES light at all runs 100% fine without
punching it
TIA
Old Apr 26, 2006 | 07:40 PM
texinteg's Avatar
Stupid idea but are you running high test?
Old Apr 26, 2006 | 07:42 PM
High test?
Old Apr 26, 2006 | 07:43 PM
texinteg's Avatar
Premium Fuel.
Old Apr 26, 2006 | 07:50 PM
I had a H/c LT1 i know i have to use premium fuel......
Old Apr 26, 2006 | 07:53 PM
texinteg's Avatar
Like I said it was a stupid Idea but i had to ask.
Old Apr 26, 2006 | 08:03 PM
Anyone else?
Old Apr 26, 2006 | 10:39 PM
No one has a clue?
 Michael S. Palmer
Old Apr 26, 2006 | 10:52 PM
98LS-WON's Avatar
Try a good top-end cleaner. You might just have crap built up in the chambers.
WOO-HOO!100 posts.
Old Apr 26, 2006 | 11:37 PM
Its a pretty bad detonation and its only got 32k miles im gonna try it anyway but are there any other sugestions
Old Apr 26, 2006 | 11:58 PM
thunderdan74's Avatar
Is the PCV system sucking a lot of oil in the intake? Check behind the throttle body to see if there's oil puddled in the intake.
Old Apr 27, 2006 | 12:12 AM
BigE_LS1's Avatar
I have a 2002 ws6 a4 with 34000 on it and it does it every now and then . I can tell you that it is your gas "you have to use premium fuel 93" . All I use is 93 and it still does it from time to time . I think that I am just getting bad gas from the store. For me when it does do it it's at about 4800 to 6000 rpm. Is that when it's doing it with your car?
Old Apr 27, 2006 | 12:14 AM
keliente's Avatar
Big problem with cars ingesting oil via the PCV system. Oil being consumed = diluting the a/f ratio = spark knock. Especially in 01-02s.
Add a catch can.
Problem solved.
Old Apr 27, 2006 | 10:32 PM
Or, just delete the PCV system like I did.
Old Apr 27, 2006 | 10:50 PM
BLKWS.6's Avatar
Pull a spark plug and check for oil, I hear the PCV is evil in these cars, as it seems to be in mine.
Old Apr 28, 2006 | 07:40 AM
i pulled the intake manifold when i did the knock sensors and the runners looked normal ( little greasy looking ) but i wanted to put a catch can in it anyways. anyone reccomend a good cheap catch can?
Old Apr 28, 2006 | 11:04 AM
keliente's Avatar
Just get an air/water seperator from Lowe's/Home Depot.
Old Apr 28, 2006 | 12:06 PM
white2001s10's Avatar
What exactly are your symptoms of detonation?
audible knock?
knock on scan?
spots on sparkplugs?
Are all the sparkplugs the same?
detonation on all cylinders or just one?
Have you tried raising the octane to see if the knock goes away?
Old Apr 28, 2006 | 02:11 PM
audible knock?
knock on scan?
its audible knock, i havent been able to pull the plugs yet and i dont really have a place to rais the octane at, the race track isnt open right now
