Cometic head gaskets
Although many have used them and had no problems w/out spray... if you are having a leak then you need to use some copper spray next time to be safe. Everyone that has used the copper spray has been leak free (that I know of) with the cometics. Also make sure everything is perfectly clean and torqued down properly, and use the copper spray, then you should be fine.
I plan on using the copper spray when my cometics get here.
you better get that fixed...coolant in your oil is not a good thing.
