Rate My Mechanical Skills!!!!!!!!
My most complex mechanical experiment in the past has been changing out the timming chain and gears on a LT1 (3times, dont ask), fuel pump, and removing the axle.
Im kinda concerned about taking on these mods because everyone's defenition of "easy" is different! I did not find the timing chain and ect. that difficult, just rather time consuming.
In yalls opinion, should I beable to do these mods, myself? I think so. I have never NOT benable to do something mechanical, I just havnt embarked into the internals of an LS1, yet. Thanx.
To owning this car now:
And doing almost ALL the work on it myself minus the actual pulling of the old cam out and putting it back in, with the timing chain, I am quite sure that you will be able to pull off the Longtubes yourself
. Yes, I am the poster child for "Former Ricer gets a Clue". Im proud of the fact I just kinda dove right in and learned it all myself - Ive learned more about cam's and valvetrain and motors in general in the past year and a half then I ever knew before. Oh, by the way, my headers took me about 8 hours the 1st time. 2 hours were getting the old manifolds out, about. 30 minutes for the passenger side header, about 5 hours for the driver side haha. Lifting the motor an inch wasnt so fun haha. But, got it done. Ive never touched the internals of any modern engine let alone an LS1. I decided to change the cam and springs on my LS1 early this week.
With the right tools and some excellent instructions like those on LS1Howto. It was a piece of ****.
Once you get started, it all drops into place without any hassles.
But like others have said. Check, double check and then triple check everything. Pay particluar attention to dialling in the cam and make sure the cam plate is bolted back in with loctite and the right torque pressure. A mate was telling me that his workshop has fixed a couple of DIY'ers cam installs where this plate was loose and the cam was moving back and forth.
Jump in and give it a go.
Probably the most useful tool I had when doing my cam swap. And MightyBoBo... I dont know what else to say but.. damn...
